11-04-2022 10:00 PM
Hello, I am unable to text or call. Username ZM2. Account is in good standing.
Tks
11-06-2022 09:03 PM
tks everyone, i have sent in a ticket.
11-06-2022 02:16 PM
@mixim10 there is no number to call CS agent
@ZM2 open ticket with CS at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
11-06-2022 02:14 PM
I would still call the customer support line otherwise text a CS_agent.
11-06-2022 02:10 PM
The problem is both ways, and no it was not a number transfer. My account had been suspended and then re-activated, seems to have been problems since then.
11-05-2022
08:32 AM
10-09-2023
08:10 AM
Are you a new user?
If you are a new user porting from another provider you may have to call the Number Port team .
It is Telus -- If the porting was not done properly, could be that your OLD provider has NOT passed the number to PM network yet. Prior to changing your SIM you would have had to answer YES to a text message sent from your current provider to verify that you would be porting your number to PM
11-05-2022 05:14 AM
@ZM2 wrote:Hello, I am unable to text or call. Username ZM2. Account is in good standing.
Tks
Did you try reoboting your phone?
11-04-2022 11:10 PM
There might be an outage in your area.
Check map to be sure:
11-04-2022 10:28 PM
Try raising a ticket regarding this. The customer support agent will fix the problem.
11-04-2022 10:07 PM
@ZM2 , is your phone connecting to the network? Is the problem only for incoming calls or text only or both ways? If it is incoming only, did you perform a number transfer that might not have completed successfully.
