03-23-2024
05:07 PM
03-23-2024
08:03 PM
computergeek541
@CS_Agent please help. Any help.
My wife and I are both use PM as our service provider. After the APN change. My wife can no longer send or receive mms while I can. I've made changes to her APN, added, deleted APN. Nothing works. She has a Oneplus 9T. Any assistance would be greatly appreciated. Thank you
03-23-2024 08:47 PM
Try setting your Sim card to lte first. Don't know your phone but it worked for me right away.
03-23-2024 05:41 PM
Got it. Sorted!! Thank you!!!!!
03-23-2024 05:39 PM
With OnePlus, there might be a bit more work then simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensivitve and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
03-23-2024 05:34 PM
She has a Oneplus 9 Pro 5G
03-23-2024 05:30 PM
03-23-2024 05:26 PM
@FUDGEPumps what phone do you have?? brand and model?
your phone might be impacted by this announcement:
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
