eSim card installation
richardsmile
I was trying to install eSim card on PM app, but it was unsuccessful and it shows eSim not Installed, something didn't go right while installing your eSim. Then I went to Cellular to add eSim. And it asks me to use QR code which I did not find in my activation summary email. Can anybody help with this? Thanks
@richardsmile
they usually reply on the same day, and yes, they reply no weekend too
if you don't receive any reply tomorrow morning, message them again
richardsmile
Thank you! How soon CS agent normally reply messages even on the weekend night?
 @richardsmile so, you checked  Sim Card Manager and Public Mobile eSim not there?
You used the PM app and got the Step 6 to finalize the activation??  If you did and dont see the QR code to install eSIM, please check with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
