03-14-2024
07:03 PM
03-15-2024
01:42 AM
computergeek541
Looking for help.
Can't receive text messages. Tried everything even turning on airplane mode. Can anyone help please.
03-14-2024 07:14 PM
Okay so if you ported and you did not have the old SIM card number to reply yes, that means I didn't failed. I will send you another phone message with the phone number to call to redo it. Make sure that that account is still active and you put back the SIM to receive the text.
03-14-2024 07:09 PM
I can receive phone calls. I tried porting it recently but it said failed. Most likely due to me forgetting to put in my old SIM and pressing "Yes" to confirm.
03-14-2024 07:07 PM
How able phone calls, can you receive them? Did you port your phone number recently?
