11-14-2023 02:40 PM
I just switched over to PM from Fido yesterday. Set up of eSIM went fine. Received 2FA SMS. Able to receive SMS from people within Telus network, but cannot receive SMS or phone calls from people outside of Telus network (cannot receive SMS or calls from people on Fido). Also cannot receive Full Access Confirmation SMS. Both my account and my mom's new PM account have the same problem.
03-25-2024 01:20 PM
HI @Jentollar09
sent. Please check your Community inbox
03-25-2024 01:19 PM
What is the Telus porting number
11-15-2023 01:55 AM
@Sookz3 wrote:could i also get this number? having the same issue. My issue is with Freedom and my sim has been destroyed. No way to confirm port.
Before doing anything else, you'll need to buy a Freedom SIM card an attach it to your existing Freedom Mobile account. Don't call the Telus porting team yet as they won't be able to help.
11-14-2023 04:12 PM
HI @Sookz3
number sent. Please check Community inbox
11-14-2023 04:11 PM
11-14-2023 03:45 PM
11-14-2023 03:42 PM
Yes, my mistake was not leaving in the old SIM to receive the porting confirmation request SMS from Fido. I called the Telus Porting Team with the number you gave me, and they requested another port from Fido. I put in my old SIM again, and received their SMS message. I replied YES. And it went through. I am now waiting for things to finalize, so I can test things out again. Thanks.
11-14-2023 03:38 PM
@sophieducey Are you still needing the porting number? Please check your message inbox top right..
11-14-2023 03:08 PM
11-14-2023 02:46 PM
Did you actually do phone number transfer from Fido?
Did you follow porting procedure? Leave old SIM in a phone, reply Yes, etc.?
Can you SMS/call anybody? If yes, WHAT number they see?
11-14-2023 02:42 PM
Hi @dreamplayer
did you got the sms from Fido to approve the port? did you reply yes in time (within 90 mins)?
there is a porting team to call and they can tell you what happened, I will send you the number to your community inbox
