Cannot make and receive a call
luyenpham
My phone is activated but I can not make and receive a call.
@BKNS27 wrote:
@luyenpham
Did you just ported your number over to PM?
If so, did you reply to the text from your old carrier with the old SIM in your phone?
The inability to make outgoing calls is unlrelated to an incomplete number port. Outgoing calls would work even if the number porting failed.
@luyenpham
Dunkman
@luyenpham
Does data and text work? Which plan are you on?
There have been talk issues recently with the VoLTE roll out.
Other troubleshooting advice:
Try to manually select with 3G Network or LTE network
Network reset of phone (this will erase Wifi password settings)
Toggle airplane mode on, then off.
You can also try the SMI card in another working phone. To help determine whether hardware issue versus PM service problem.
If PM service problem, then you will need to contact customer service agent.
lfaber
Try rebooting your phone. Do you get the PM signal?
