07-25-2022 11:21 AM
For the first month everything was great! I could login no problem, signed someone up to get rewards ... I could track rewards etc ... NOW? No login at all ... I get this message when I go to selfserve.publicmobile.ca ...
"message":"Request header or cookie too large"
}Any ideas? I like the price and convenience but this is a major issue for me!
10-10-2022 03:40 PM - edited 10-10-2022 06:35 PM
@joyker @newmanwilson (edit: wrong username tagged) You're unable to login using incognito or private mode? Have you tried using a different browser?
I just tried with Firefox and had no problem logging into the self serve account. Perhaps, there was a temporary website issue when you tried earlier.
10-10-2022 02:10 PM
not resolve issue
07-25-2022 11:56 AM
HI @joyker glad it works.
Yes, the cache is a big enemy to PM site. Always try Incognito mode or other browser if you encounter any problem
07-25-2022 11:35 AM
Thanks so much for this ... the incgnito suggestion worked for me ... I'll just do that for now but will keep this suggestion in mind ... thanks!
07-25-2022 11:32 AM
@joyker try my second suggestion to contact customer service it's easier
try to pm them here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 you will get a response from them in your community envelope
07-25-2022 11:29 AM - edited 07-25-2022 11:29 AM
HI @joyker since you tried all these ways, you likely need to open ticket with CS Agent
Yes, the quicker way is to use SIMON/Chatbot to open. No, worry, type exactly what I suggest below and you can open a ticket win 30 seconds (or you can use direct message as well):
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
07-25-2022 11:27 AM
Thanks much for the info ... this is the first interaction in 2 months with someone! I have tried different devices, cleared my cookies etc ... still get the same issue. Simon? It's like going around in circles! If I could login I wouldn't need to submit a ticket ... and you have to be logged in to submit a ticket? Catch 22 for me!!!
07-25-2022 11:25 AM
@joyker there have been many issues with login since the upgrades try a different device to login, use a different browser in ingognito mode, if problem persists
you will need to open a ticket through Simon to speak to a customer service agent they will help you mention update email for self serve account
Click here if you have issues using Simon , try to pm them here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 you will get a response from them in your community envelope
07-25-2022 11:25 AM
@joyker Try to use Incognito more, or clear cache and reboot the browser. Or try to use a completely different browser (Edge/Firefox/Chrome). Or try on another machine
07-25-2022 11:25 AM
HI @joyker Look like it could be just cache issue, please try with Incognito mode
Or if you have a laptop/desktop around, try accessing from there
07-25-2022 11:23 AM
Try clearing the cache files. Try using incognito or secret mode.
Try a different web browser. Firefox works great for me.
