Cancel
Jimpassingham
I cant remember my email login. And I need to cancel my plan.
Meow
Do you remember if you have autopay active? If you do not have autopay set to on you have nothing to do. After 90 days account will be closed due to no pay.
Otherwise contact agent to reset your log in.
- Send a private message to the CSA - agent by clicking Here
popping
@Jimpassingham
If you have autopay enabled, login and disable the autopay.
On you next renewal date, your account will be suspended without payment.  90 days after suspension, your account will be canceled.
You can also port your PM number to another provider.  You PM will be canceled after PM released your number to your new provider.
Outdoorsman
@Jimpassingham
hi  if  password reset doesn't work for you  then
 to reset password or  account email you need the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
      https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
HI @Jimpassingham
To cancel your account,  you can port out your number ,  which you need to login to My Account and get the account number.  Or you need to login to My account to just disable Pre-Authorized payments
You don't have access to My Account, open ticket with CS agent and they can help:
at https://publicmobile.ca/chatbot.
First type Forgot Login,
