4 weeks ago
Do not cancel my current plan with you. I made a mistake in replying to your email about your summer plans. Do not see where to click YES2 for the $30.00 Canada - US- Mexico
3 weeks ago
Thank you. Have figured now.
3 weeks ago
Thankyou. Yes it was easy afterall.
4 weeks ago
not emailed but messaged to you. If you want to take advantage of that offer, just reply YES2 to the message.
4 weeks ago
You don't click the Yes2, you reply Yes2 using text
But if you need PM to help, open a ticket
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
4 weeks ago
@lenore1_telus-1 wrote:Do not cancel my current plan with you. I made a mistake in replying to your email about your summer plans. Do not see where to click YES2 for the $30.00 Canada - US- Mexico
We are all customers here like you. Nobody from Public Mobile monitoring these forums. If you need customer service, this is how.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
