11-10-2021 11:56 AM - edited 01-06-2022 03:59 AM
Hii… i have a number associated with my email.. its a number for my father in law.. and now he is out of country… so i want to cancel the autopay…
11-10-2021 02:19 PM
@Aman-88 Just to add to what's already been mentioned, a reminder that if you're just temporarily pausing his plan whilst he's out of the country, you must make a payment before the 90 days of suspension are up, otherwise both the account and number will be deactivated. It's recommended to make a payment around the 85th/86th day to deal with any issues.
11-10-2021 01:44 PM - edited 11-10-2021 01:49 PM
@Aman-88 wrote:Hii… i have a number associated with my email.. its a number for my father in law.. and now he is out of country… so i want to cancel the autopay…
Are you also the one who activated the account? Then you should also know the password? Or use the Forgot password feature to reset.
Once logged in, just disable Autopay:
Note: If you disable autopay but there is a balance in Available funds enough to cover plan cost, the system will still renew at next renewal date. To stop it, you'll have to use the Suspend service feature (in Lost/stolen page).
11-10-2021 12:15 PM
@Aman-88 : If you can't log in then you would need the 4 digit PIN of the account to toggle off autopay in the 611 or 18554public service.
Another option is to pause the payment card for the renewal. Then it will suspend the account and won't try again.
11-10-2021 12:08 PM - edited 11-10-2021 12:10 PM
@Aman-88 If you have the PM SIM and phone with you, you can use *611 to disable Autopay
If you don't have the PM SIM and phone, you will have to login to My Account and disable it there. You might want to ask him about the My Account login credentials.
https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/
Then click Manage Autopay and then click Remove Autopy
11-10-2021 12:02 PM
Log into his account to remove autopay and that will cancel his account.
11-10-2021 12:01 PM
just to you know for Reactivate A Suspended Plan
Missed a payment? After your plan expires, all you need to do is top-up your balance to keep the current plan going. You have up to 90 days to make a payment and, after doing so, your payment cycle will restart and your service will resume.After 90 days of non-payment, your account will be permanently deactivated, which means you will:
11-10-2021 12:00 PM
How To Remove Your Payment Card
To update or remove your credit or Visa debit card details,
1. sign in to Self-Serve. Once signed in,
2. click on the ‘Payment’ tab,
then scroll to the bottom of the page and select ‘Manage my card’.
you will have the option to either select ‘Remove this card’.
You will need to review and confirm this change to your account,
and if can't fix it you Have To Submit a Ticket To Contact Customer Support Agent by CS_Agent, and Explain your issue to
they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck..
