Cancel Subscription but no access to phone number
anotherguy123
@CS_Agent I had bought an e-sim a couple of months ago for a family member who was visiting us. It worked great for their time here but now they are gone and removed e-sim from their device. When I try to login, the system asks to verify my full access by sending a code to that same number which I don't have access to and can't add onto my phone. How do I proceed? I have 1 more day until the subscription renews. Please help!
9 REPLIES 9
anotherguy123
Thank you all for your prompt responses and help. I have messaged support. Let's see what they have to say.
dust2dust
If support doesn't get back to you, 2 ways:
1. If you know the 4 digit account pin then you can dial 1-855-4-pu-blic from any phone and turn off autopay
2. Since you say it renews tonight, you could login to your credit card account and pause or lock the card overnight. Then the next day turn it back on. That will stop the account from renewing because autopay only tries once.
anotherguy123
I keep getting reverted to this page:
We’ve noticed you have an active Public Mobile service and would like to confirm your full access.
A 6 digit code associated with your EverSafe ID will be sent to phone number . We will need you to confirm this number.
@anotherguy123  Please submit ticket with support to remove credit card info right away
private message   To CS_Agents click
@anotherguy123
Hit Resend Code and you will have the option to send the 2FA code by email, call or text.
But you should also have the QR code in the email PM sent to the registered email.
anotherguy123
Thanks for a prompt reply. I just tried this and it keeps taking me back to the same page without prompting me to add an email id instead for the code.
HI @anotherguy123
on the security code page, click "Didn't receive code?" , then choose Send email
or if you know the 4 digits code, you can use *611 or call 1-855-4PUBLIC and disable autopay there
@anotherguy123  Tap resend code a few times you should get option to send code to email instead and turn  off auto subscribe or get support to remove credit card infor from file right away
Turn  auto pay  OFF/ON  3 easy clicks
Link for support here
