Cancel SIM order
AndreaNew
I’ve ordered a SIM card but I’m wondering if I can switch to an eSIM and cancel the physical SIM order?
CSA_PM
Customer Support Agent
Hi  there!
Unfortunately if a simcard was ordered it cannot be activated with esim. It can be changed after .
AndreaNew
A new activation, just today.
CSA_PM
Hi there . Is your account new activation? or you are an existing customer?
Chalupa_Batman
Hello @AndreaNew
Since you've already ordered the physical SIM card, you will have to reach out to a CS Agent to be able to change it to an eSIM instead. Here's how.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact customer service.
eddieO
@AndreaNew probably would depend on when you ordered the SIM card, if it was just today you could probably cancel the order but if it was before today there's a good chance it's already been mailed out. Best to contact a customer support agent as they should be able to confirm. Use the link that was shared by slusagm.
slusagm
You can try, but likely you have to activate to physical sim first.  But check with PM
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
