01-17-2020 07:21 PM - edited 01-05-2022 09:04 AM
🤾⛹️delete voicemail! 🤔 don't like it and don't want it🤸🏃🚶
01-18-2020 05:51 AM
@LovesToPM wrote:
- or forwarding your calls to a non-existant number (instead of your voicemail number)
Specific to forwarding to a non-existant number - Here is how to set all conditional forwards that normally go to voicemail:
Forward all unanswered calls to any US number (example is an invalid hawaii area code #), which will never go through, and will present the caller with a fast-busy instead of voicemail
*004*8080000000#
Reset back to default (public mobile's voicemail) by dialing this:
##004#
You can also set your conditional call forwards to any number of other "entertaining" options: ![]()
01-17-2020 09:20 PM
The discussion about how to get a plan without voicemail or how to disable it has been moved into one message thread for organizational purposes.
01-17-2020 07:52 PM
@dboxtvinfo715 wrote:Slam dunk🤸running🤸🚶🏃 flip🤾⛹️
@dboxtvinfo715 those would be the literal interpretation of your hieroglyphics. But what are you trying to say with them? Acutally you know what, don't worry about it, I give up anyway.
01-17-2020 07:49 PM
01-17-2020 07:49 PM
@dboxtvinfo715 As has been mentioned in another thread about this very topic, if you really don't want voicemail, do as @LovesToPM has linked, and leave a voicemail greeting along the lines of, "Sorry, I DO NOT want voicemail, so please either text me, or call some other time."
01-17-2020 07:46 PM
@dboxtvinfo715 what does this roughly translate into in English?
01-17-2020 07:31 PM
More about extended greeting message here: https://productioncommunity.publicmobile.ca/t5/Getting-Started/Re-Disable-Voicemail/m-p/213805/highl...
More about how to use your voicemail here: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-To-Use-Your-Phone-and-Plan-Feature...
01-17-2020 07:29 PM
01-17-2020 07:28 PM
@LovesToPM wrote:
@dboxtvinfo715 wrote:delete voicemail! 🤔 don't like it and don't want it
No we cannot, but there is workaround.
You may prevent callers from leaving a voicemail
- by adding an extended absence greeting
🐥🐤🐣🦉where around what 🐿️
01-17-2020 07:27 PM
@dboxtvinfo715 wrote:How do I remove voicemail I don't like it
Disable voicemail workaround: https://productioncommunity.publicmobile.ca/t5/Getting-Started/Re-Disable-Voicemail/m-p/213805/highl...
01-17-2020 07:23 PM - edited 01-17-2020 07:26 PM
01-17-2020 07:20 PM
