Can-us-mex plan: is it just data or does the calls and txt work too?
BlossomSkys
I have the Can-Us-Mex plan, and am going to be traveling to Mexico soon.  Does the plan just cover data or will txt and calls work too?
Thanks!
ORNGNBLK
@BlossomSkys  Be sure to leave roaming turned on, there is no extra $ for this as it’s included in the prepaid plan, so you don’t have to worry about coming home to surprise bills!
hi @BlossomSkys
everything will work when you are in US and Mexico just like you are in Canada.  So, voice calls, data and text all work
SKSuh
Voice text and data worked flawlessly with my iPhone in Mexico a few months ago
