07-20-2017 02:46 PM - edited 01-04-2022 02:23 PM
I have four add-ons active (including US roaming), but they aren't appearing in my self serve account as active on my main page.
When I go to "Plans and Add-ons" I can see them as active, but then when I go to view my usage under "Data & Add-on Usage", none of my add-ons (or my current data plan) show up.
07-20-2017 03:54 PM
Just looked at my account. Plan says I have data but it does not show in my add-ons where it normally does. I know it's been used completely.
Similarly, a data add-on I had last week is gone because it is also used up.
07-20-2017 03:40 PM
The odd part is that my add-ons still show up under "Plan and Add-ons", I just can't view their usage or manage them.
07-20-2017 03:37 PM
Conversly, it's exactly the same as the IN CANADA data and long distance packages. Once used up, all traces disapear.
07-20-2017 03:32 PM
That could be the case. With the way it's currently set up, it's super unclear. Makes me think: Am I experiencing an error? Or do I need to buy more data? Even if it's maxed out, it should still tell me it's maxed out. Poor design.
07-20-2017 03:29 PM
I believe data add-on detail disappears from the account when it's all used up. This may be the reason why it does not show up in the account.
07-20-2017 03:28 PM
I have a 1gb data add-on (local) and a US data + call + text roaming package active right now. I can see them in some views in my selfserve, but not when I go to "View My Usage" (nothing shows up there). Attached screenshots for clarity.
My add-ons do not show up under "Overview" but show up under "Plan and Add-ons".
07-20-2017 03:22 PM
is it a talk, text and data add on, Or just a data add on for the US roaming? And did you buy more than one of the US add ons? You can't stack US roaming add ons, so you can only get another roaming add on of the same type every 10 days
07-20-2017 02:59 PM
I purchased the add-ons already and have been using them for several days. The US roaming should have 5 days at least still left on it. Nothing is showing up when I go to actually check the usage though.
07-20-2017 02:49 PM
Do you have funds listed in Available funds? Adding adds ons here is a two step process. If you see a balance in the available funds, you can use those to purchase the add ons. Please note you cannot stack US add ons of the same type.
