6 hours ago
Guys,
I have an issue. I bought a long distance addon pack approximately, months apart. While using i noticed a strange pattern. The addon pack is India long distance call pack. = 750 minutes. After 260 minutes of usage I bought another 750 minutes of long distance addon pack.
After some time, I noticed, the minutes from both the addon pack are debited after the usage. Please find the attached snapshot. The ideal scenario should be the first one should be showing the current usage pattern and the second one, should be 0% usage. Is this just an User Interface error? or the addon is debited from both the packs? could you please let me know if you encountered this issue before?
Thanks for your help!!!
5 hours ago - last edited 5 hours ago
@Canadaian_Monk As a side note, are you aware that PM has this new Canada-US 30-day plan available that includes 1000 long distance minutes to a handful of countries including India?
5 hours ago
Thanks @Handy1 . This seems like a bug. even if they credit, I am not sure, this will be a permanent fix. next time, when i make a call, the minutes stays same or it will be debited from the account. lol. Thanks for your support. I will try following up with the support too.
5 hours ago
Thanks @EB0 . Understood. in my case, it uses both at the same time. LOL.
6 hours ago
I has the same issue before, I had two data add-on without expiry date, and the system used the second one before fully consuming the first one, I don’t think it’s a big issue as those international minutes don’t have expiration dates.
6 hours ago
@Canadaian_Monk I would show this to support and ask them to credit back the mins to the one add on . I’m sure they can do something for you
