2 hours ago
In the PM web page, the "Data Usage" in the Overview page is almost 10 times more than the total in the "View Usage History" for the same period (Aug 10, 2024 - Aug 16, 2024).
"108.55 MB used" is indicated Under "Data Usage". I then click on the "View Usage History" at the bottom, and filter it to show only Data, the total data used up till yesterday (Aug 10, 2024 - Aug 15, 2024) is 9.81 MB. I do understand that it does not include my data usage for today, but I am home all day with wifi, not using data at all.
Does anyone have the same experience?
Overview
View Usage History
an hour ago
@CH13811 , just to make sure that there isn't a data caching problem here, please check again using incognito mode.
2 hours ago
My data has been 100MB over for the past two months. Support says they have been working on something and the overview is out of whack.
2 hours ago
@CH13811 did you also use your phone to track the usage??
I would open ticket with PM and have them to confirm
Please open ticket with PM support:
