06-22-2022 08:52 AM
06-22-2022 10:52 PM
@Adamparsons8080 wrote:Can't sign in, Can't add mins by credit card.
@Adamparsons8080 Have you ever created a self serve account before, if not you can register for one here:
https://selfserve.publicmobile.ca/self-registration/
NOTE:
If you have been in nonpay/suspended status for over 90 days, then you lost your Public Mobile account, phone number, and access to self serve.
Otherwise, see @Meow 's post.
06-22-2022 08:56 AM
What is the issue? Incorrect password? Did you try password change.
Did you try different browser; incognito mode?
Do not try too many times as you will be locked out for 15 min or longer.
If everything fails, contact agent.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
