05-14-2024 11:22 AM
Had an issue transferring my moms phone number to Public mobile, getting the above error code, can sign out of contact for support, which leads to no where, with the account created, how can I go back from step 6 to 1? Spent an hour on the phone with Koodo and they said to use account number this time.
thanks a bunch
05-14-2024 11:42 AM
Thanks for the messages and support, ticket sent.
05-14-2024 11:36 AM
Yea, 30 minutes to hours wait time
05-14-2024 11:34 AM
Using app, Miri on app worked for me, but locked it for her.
05-14-2024 11:33 AM
Deleting app and reinstalling didn't work, trying to log in and continue on my phone also didn't work, it's frozen on step 6 with no option to click back. Sent a pm already, was hopping for a quicker answer.
thank you
05-14-2024 11:32 AM
Are you using the PM app to activate her account?
If you are, don’t use the IMEI and only use her previous account number.
05-14-2024 11:31 AM
@Bob1802 were you signing up with the public mobile app? You can try to uninstall and try again. If it doesn't work, use the chatbot to create a ticket for PM to review and assist.
Should that link not work send a private message using the below.
