07-26-2023 10:55 PM
I can’t send international text messages. Tried to submit a ticket several times but always told something was wrong. What’s wrong with Public Mobile?
07-27-2023 09:04 AM
@Danhqf try a phone reboot first.
Make sure you are sending SMS and not iMessage, maybe even turn off iMessage first and test
try texting other numbers in China
try both 01186 and +86 and the mobile number
if still unable to send, let us know if the message just sent but the receiver not received, or you actually get an error message on your end
07-27-2023 08:53 AM
Hi, thanks for responding to my message. It’s not a new account. Text to Canadian mobile numbers no problem. I had text to Chinese mobile numbers before. Have not received messages from them though. I am using iPhone XS Max.
07-27-2023 08:49 AM
Hi, thanks for responding to my message. I am using iPhone XS Max. I can send text messages to Canadian mobile numbers but not Chinese mobile numbers. I could send previously but not now. The number format I put in was +86xxxxxxxxxxx. It showed no error on my phone but the recipients never received the messages. I have already created a ticket with your link. Thanks.
07-26-2023 11:21 PM
a little premature to open a ticket just yet...we can likely help with that. Is this a new account you're using ? Can you text your friends in Canada ok ? Have you rec'd texts from whomever your trying to text to ? have you texted them successfully in the past ? What kinda phone you using ? Answer some or all and I bet we can help fast.
07-26-2023 10:59 PM - edited 07-26-2023 11:00 PM
@Danhqf which country you try to send the text to? how you enter the phone number in the To field?? you got any error? 9r no error and just your friend never received it?
And you are using Android? you can text locally without problem?
To open ticket, please use this link to direct message PM
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you theresupport
