10-02-2025 08:31 AM
I recently purchased a Nothing Phone 3 from Best Buy in New Brunswick, Canada. I transferred my physical SIM over to it and set it up. Everything seemed to be working until my sister tried to send me a group MMS message from her iPhone and I didn't get it. All my other Android using family members received the text but me, it showed something was trying to download from her but it would not load and every time someone replies I get another message trying to download from that person and again it doesn't load. Previous to the Nothing Phone 3 everything worked fantastic, never had any issues. I checked all the settings and everything looks correct. Is this a carrier/phone model compatibility issues?
10-02-2025 09:37 AM
Thank you, this seems to be working now!!
10-02-2025 09:17 AM
It's an APN settings
You can ignore the fields you dont see, and here is the full APN settings , update accordingly
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D (or try: 4D4F)
10-02-2025 08:53 AM
Also, in the upper right corner in the status bar it shows VoLTE which is why I asked the question if it's a carrier/phone compatibility issue
10-02-2025 08:46 AM
In the settings MCC and MNC do not exist
10-02-2025 08:36 AM
Try update the APN
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
