04-24-2022
11:01 AM
04-24-2022
05:22 PM
computergeek541
Hi, my name is Stephanie Broadhurst and i am trying to sign in to my public mobile account and I’ve tried resetting the password but I was what would seem that it was successfully changed. But then when I actually sign in with the new password it would not work and with the 3 attempts I then got locked out. I tried waiting and resetting it, but would say I am locked out. Would appreciate your help.
thanks,
04-24-2022 09:30 PM
@sbroadhurst7 - so you are receiving an email to reset the password then? I am unclear if you got to that point.
If you have not registered for an account yet, you can do that here: https://selfserve.publicmobile.ca/self-registration/
Otherwise, if the Forgot your password link IS sending you via email the reset details, then clear your browser's cache/cookies, or try a different browser, or open a tab in incognito mode in the browser of your choice. Then after doing that, try logging in with the new password you set.
04-24-2022 11:40 AM
If your pw still isn't working after you wait. The only option is getting the CSA to reset it for you
04-24-2022 11:25 AM
Most likely your account is temporary locked due to too many log in attempts.
Try again in 1h and if still does not work, ask agent for assistance.
04-24-2022 11:05 AM - edited 04-24-2022 11:06 AM
Wait a full hour before trying again. If you can't wait that long you may get customer support before then....put "password" reset in the subject line and a detailed message explaining the issue.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
04-24-2022 11:02 AM
@sbroadhurst7 you can wait another 15 minutes and try again
or it will properly better to just open a ticket with PM Support in your situation:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
