11-25-2023
06:40 PM
11-25-2023
10:28 PM
computergeek541
I have just paid and signed up with PM and they want me to make my phone a trusted device by texting me a code but the code is not coming through. I can't make calls or texts or anything until this is done. What should I do?
11-25-2023 06:59 PM
If you're coming from another provider, make sure you have your PM network enabled
11-25-2023 06:46 PM
It only comes with a "resend code" option and doing so does nothing. I will attempt to send a support ticket. Thanks.
11-25-2023 06:44 PM
@Nitbit Tap the didn’t get code option you should get option to send code to email instead of still no luck please submit ticket with support to help you gain access to your account
send a private message To CS_Agents click
VVVVV Link below VVVVV
