Google One VPN won't connect
RedRock
Works fine on wifi, but it won't connect when I'm on PM cellular.  Any advice or tips?
2 REPLIES 2
hi @RedRock I never tried Google One VPN bit i used multiple others without problem.  I don't think PM intentionally blocks VPN
Try Reset All Networks
and if same, you need to ask Google for suppoet, or hope someone using that can advises
Chalupa_Batman
Never heard of Google One VPN. I use NordVPN on my phone and works like a charm.
