3 weeks ago
I have a Google pixel 5 and checked IMEI to see if compatible on PM network and it is. When I am in the city everything works great. When I am at the cottage dropped calls or no connection to make calls. Someone said I should connect with volte how do I do that and if I do does it automatically then revert back to 5G when in the city??
Otherwise I think I will have to change providers as I found out PM does not have WiFi calling.
3 weeks ago
Thanks I will look into this with Koodo as I do need something for out cottage way
3 weeks ago
@DebW wrote:I tried that a few times and nothing different and it pretty much stays on LTE
Hello @DebW
Try turning the phone's Airplane mode on and turn off your phone for 5 minutes. Then turn it back on and turn Airplane mode off. This will reset your connection to the Public Mobile network.
On a side note, if WiFi calling is something you'd prefer, Public Mobile has created offers to join their sister company Koodo. You should look into it.
https://www.publicmobile.ca/en/get-help/articles/switching-from-public-postpaid
3 weeks ago
3 weeks ago
3 weeks ago
You can start with Reboot phone and Reset Network Settings
If you don't see improvement, try changing network mode to 4G or LTE
