Can't receive calls. Only txts to/from some people working
06-11-2019 12:17 AM - edited 01-05-2022 05:19 AM
Hi,
Just signed up and super frustrated because if someone tries to call me, my phone doesn't notify me and it just goes to my old voicemail.. Which I can no longer access.
Also, text messages are only working with some people. Some people have sent texts I never got, and I have sent texts that they never got.
Please fix or I will switch back.
Joining Public
06-11-2019 08:37 PM - edited 06-11-2019 08:38 PM
@PMFanatic wrote:
Moderator hours are as follows and generally you can expect a response within 1 hour or up to 48 hours depending on volumes...
- Weekdays 8:00am - Midnight (Eastern time)
- Weekends: 8:00am - 10:00pm (Eastern time)
Best of luck!
@PMFanatic just a friendly suggestion: don't include this info I've quoted here--it's already on the page you linked, and more likely to remain up to date there should someone stuble upon your reply down the road.
06-11-2019 12:34 AM
If you ported your number it can take a bit of time to transfer your services over. If you want to proactively investigate this issue, I would recommending messaging the kind folks at the Moderator_Team via this link to investigate your account and to provide some additional insight into your issue.
It helps to provide a detailed description of your problem and what your resolution goals are so they can best assist. If you are having troubles contacting the Moderator_Team, refer to the following knowledge base link.
Best of luck!
06-11-2019 12:22 AM - edited 06-11-2019 12:23 AM
@Soundwave wrote:Hi,
It sounds like you ported from another provider. These things can take some time depending on the provider. You could keep using your previous service until it stops. At which time your port should be complete. Then put in the new SIM and you should be good to go.
