07-10-2025 02:48 PM
My old phone numbers message app is not working anymore(fido 3G issue), so i can not receive the 6-digit code. what can i do with situation.
07-10-2025 05:34 PM
The problem not about email, the problem is about the phone number, fido just end 3G use, which i can not use phone talk , text, so i can not receive the 6-digit code from the message, and then i called fido calling center, they just told me to restart the phone, and then i can use message. Now all done. Thanks for replay.
07-10-2025 05:26 PM
Did you click on Resend Code/Didn’t Receive Code then have the 2 FA code sent to your email.
07-10-2025 02:58 PM
Hi there. I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
