05-12-2023 10:56 PM
Hi, i've this issue for a while, when somebody try to call me, 1st time always go to VM, 2nd time incoming call went through.
05-13-2023 08:34 AM - edited 05-13-2023 08:35 AM
Is it possible you have "repeat callers" set in your Do Not Disturb settings?
This feature allows a caller to ring through when it calls a 2nd time within 15 minutes when Do Not Disturb is enabled with the feature turned on.
05-12-2023 11:26 PM
@softech wrote:Pixel: Settings->Network and Internet->Internet, click on the settings icon besides SIM 1, turn on 4G calling there
At least for Pixel devices that are still receviving updates from Google, there are no VoLTE options in the settings that can be changed. For these devices VoLTE is automatically enabled as long as the phone is connected to an LTE network.
05-12-2023 11:07 PM
@judyshi what brand and model of phone do you have?
two things to try and see which one helps
1. try to enable VoLTE on your device
iPhone: Settings->Cellular->Cellular Data Options->Voice & Data, enable 4G or LTE there
Samsung/ Other Android: Settings->Connection->Mobile Data, enable VoLTE there
2. change the Preferred network type or network mode to 3G only or WCDMA only
let us know if it works better
