12-31-2021 03:56 PM - edited 01-04-2022 04:43 AM
I activated a SIM card and was unable to port the number (343 area code from Koodo) neither during activation nor in the Self Serve.
Error message:
We were unable to transfer the phone number you entered. Try one of the following options:
- Make sure you entered your number correctly.
- Select a new number.
- Contact the Public Mobile Community for further assistance.
The phone number is valid and works. What's the issue? How do I get it ported?
12-31-2021 05:01 PM
Thank you, all! Happy 2022!
12-31-2021 04:08 PM
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck and your welcome to Public Mobile
you will be very happy...with a Fabulous Service.
12-31-2021 03:59 PM
It sounds like you can pick a new number, then send a private message to @CS_Agent asking for their help with porting your old number. It may take a couple days to complete the entire process. But it's the only other option if the automated system won't accept your porting request.
All the best!
12-31-2021 03:57 PM - edited 12-31-2021 03:59 PM
@brmrsam , your number can certainly ported into PM as it was with Koodo.
But do you have Koodo prepaid or postpaid plan?
If you wish to transfer an existing numbering from Koodo Prepaid or PC Mobile, you will need to first complete your activation with a new number, then reach out to our Moderator team here in order to transfer your existing number to Public Mobile.
