Can’t make or receive calls
BobbyKennedy
Trying to call out and phone just goes beep beep beep and drops call.
what is going on?
2 REPLIES 2
@BobbyKennedy
did it just happen today?
You could be impacted by the VoLTE enabling on his account.
Try to power off the phone and then power up to try again
If still unable to make calls, try to enable VoLTE on the device itself and see if calls can be made using VoLTE
If nothing works, open ticket with PM Support and they might have to refresh your account from their end to resolve the issue
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
HI @BobbyKennedy
  are you able to connect to PM network and Mobile data working?  and text working?
there been some voice problem in the last 2 or 3 days, maybe you are one of them
If just voice problem, Please submit a ticket with CS agent  at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
