03-24-2023
11:21 AM
03-24-2023
02:30 PM
computergeek541
Perhaps I misunderstood (and I truly hope that is the case), but, is it the case that, in order to have two phones with Public, I have to get another email address?
03-24-2023 12:52 PM
HI @pjhoust Prepaid provider is like that. if you need family account for easy account management, try Koodo or Telus
But why not just use another email to activate another line?
03-24-2023 12:50 PM
Thanks for all your responses. I should have researched this 'feature' more thoroughly before I signed up. Seems to me it could pose an impediment to easy widespread adoption and is a flaw in the business model. I'll move on. Cheers.
03-24-2023 12:04 PM - edited 03-24-2023 12:11 PM
If your e-mail provider allows alias addresses, you can use an alias.
ie: yourname{at}gmail.com = your.name{at}gmail.com = yourname+kid{at}gmail.com will all end up in the inbox of yourname{at}gmail.com but are considered distinctly different addresses by the Public Mobile account system.
You can use the same credit card for more than one account. In that case I would stagger the activation/payment date so that you don't trigger your cc's fraud alert system.
Edit: I started typing this before dust2dust's reply showed up on my screen - sorry for the echo!
03-24-2023 11:58 AM - edited 03-24-2023 12:13 PM
Some email providers offer an alias function that would work here. GMail for example. If you have a gmail address then say your email address is [email protected] then you could do something like [email protected]. This will then receive all emails in the one email inbox but will satisfy this place as being a unique email address.
Adding - you can do this on the fly. It doesn't need to be set up or created.
Adding more - it happens @wetcoaster . It's the ones long afterwards that are the unnecessary echo. Thanks for being concerned about it. Not everyone cares. Newbies can be forgiven. But not regulars and even high performing regulars. Again, seems some don't care. I'm delighted to see the oracle removing those echos.
03-24-2023 11:41 AM
HI @pjhoust there is no family account here. So, one account for one phone number. You will need another email to activate the new line
A reminder, use the friend referral code form your first account to activate your 2nd account. Your 2nd account will get a one time $10 credit and your first account will get $1 or 1 Public point every cycle
03-24-2023 11:37 AM
@pjhoust Yes each phone line needs its own email
