Can't make any phone calls
ctaljeh
Hello,
My account is active but i am unable to make any calls. i tried restarting my phone and resetting network settings, i even put my SIM in a different phone but no luck. Has anyone encountered this problem? How do i get this resolved?
Thx
10 REPLIES 10
ctaljeh
Update:
Support got back to me and fixed the problem from their side.
Thank you everyone for your supportive replies. I really appreciate it.
ctaljeh
@iamcdn
Tried all these with no success
ctaljeh
Hello,
Tried your suggestion and turned my phone off for 5 minutes, unfortunately the problem persists.
I submitted a ticket to support, hopefully they fix the issue soon. Thx
iamcdn
Ok, try turning off phone, pull out sim card, wait 5 mins, put back in, turn on phone and try to make a call
ctaljeh
Hey,
Thank you for the recommendation. I tried adding 1 before the area code but still no luck.
My problem started yesterday and it was only restricted to 1-800 numbers, but later in the afternoon i was unable to make and receive any calls at all. I restarted my phone and was able to receive local calls, until this morning when everything stopped and nothing would work to fix it.
iamcdn
When did that start? Up until yesterday I didn't have to dial 1
@hTideGnow wrote:
HI @iamcdn   I think after VoLTE, everyone needs to dial 1 in front of the 10 digits
This isn't the case.
iamcdn
Are you dialing 1 + area code + 7 digit number or just area code + 7 digit number?
My problem just started yesterday and I just figured out why. I have to dial 1 before the area code. I don't know why that is now cause if I don't do it won't make the call anymore
@ctaljeh
There has been some voice issue for some customers in the last couple days
Try this first, power off the phone for 5 mins and then power up and try again
If that does not work, please open a ticket with PM support for them to refresh your account, they will be able to resolve it
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
