02-24-2023 05:35 PM
I need help. I'm not getting the email to rest the password and every time I try to get the verification through text it won't send. I need help!
02-24-2023 05:44 PM
@Dune_Epsilon if your account is active, getting 2FA by Sms should work
And you check your email spam folder?
if you really cannot find the 2FA code and need help, open ticket with PM support
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
02-24-2023 05:36 PM
@Dune_Epsilon get help from support to access your account
Watch for reply top of page to the
Right ( envelope image )
