04-24-2024 12:52 PM
I have an account that was created a few years ago and that contains a plus symbol in the email.
For example, text+text@gmail.com
I can no longer log in even though I'm using the same email and the correct password.
The error I get is "unknown request failure".
My Account
04-24-2024 01:13 PM
Have you set up Eversafe Login before?
https://www.publicmobile.ca/en/ab/get-help/articles/eversafe-faqs
The website is also finicky. You can try a different web browser, clear cache or incognito mode.
04-24-2024 01:11 PM
Did you try to use computer and clean browser, incognito mode?
