my account
Freddy4591
help, I cant log into my account
2 REPLIES 2
slusagm
did you try to use Forgot email or Forgot Password to try to get back into My Account
or if you need PM to sort it out for you, open a ticket with them.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Techfish
What issue are you experiencing? If it's an EverSafe verification code problem, you could request an email. Otherwise, you could contact an agent by private message to CS_Agent. Here's a direct link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
I hope this helps!
