Activation Help
Campbell275
I subscribed to a plan online and discovered that I needed a new phone. Purchased an unlocked phone (new) and now am unable to find a way to activate it. Put the sim card I ordered in the phone and it says it is not on a network. I'm lost and there is no way of contacting anyone for support. When I try to cancel the subscription it sends the code to the phone number that was assigned when I signed up which isn't connected to a phone so I don't get the code! Very very frustrated. @J_PM
2 REPLIES 2
RavingRaven
@Campbell275
Have you tested the Sim card in a different phone? This will determine if it's a Sim card problem or a phone problem. ( If you have completed the activation process.)
HI @Campbell275
did you use the app to complete the activation?
if not, please download the PM app on your phone and login
if you still need help with the activation, check with support agent  by direct message:
