05-20-2022 07:18 AM
I can’t get calls. I called my cell phone from home phone, the calls 1) straight to voicemail 2) cell phone not ringing 3) can you give me my 6-digit Ref. no.?
Thank you
05-20-2022 09:54 AM
Some more info and answers to the above questions will narrow things down and help the community point you in the right direction.
05-20-2022 07:39 AM
@Sung-may , did you just activate a SIM card and port over from another provider?
If you have activated a new account and transferred over from another provider, note that incoming calls are usually the last to port over.
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
If still issues, submit a ticket with Public Mobile representatives (CSA) for help; click this link: to request the transfer of your number over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protectio
Or, try performing a reset of your network settings.
05-20-2022 07:26 AM
@Sung-may for your call issues, can you at least make outgoing calls?
for incoming calls issue, please try to first reboot the phone, try it
If that does not work, change the Preferred network to 3G only/WCDMA only and see if it it picks up incoming calls
If it still does not work, try to reseat the sim card. Power off the phone, take sim card out for a minute and then put it back and power up
If you have another phone around, you can also try to put the PM SIM in the other phone try test it
What 6 digit reference number? or you meant the 4 digit PIN for you use with *611 ?
