12-16-2021 11:19 AM - edited 01-04-2022 04:50 AM
Call drops right away when I try calling out and when calling my phone it goes right to voicemail. I think I have had this problem right after my phone was reset. Is this a problem with the SIM card?
12-16-2021 12:50 PM
Thanks so much for this suggestion, that fixed the issue. I actually didn't need to change to 3G but instead just clicked on Public Mobile of the available networks that were showing and that solved my issue.
12-16-2021 12:40 PM - edited 12-16-2021 12:40 PM
Hi @crosbyoverovi , it was working good before?
try changing the network to 3G Only and see if any better.
12-16-2021 12:38 PM
Yes SMS works fine.
12-16-2021 12:27 PM
Does SMS works? (send/receive)
Maybe there is local service outage (but too small to be reported on web site).
Ideally, try your SIM in different phone or see if somebody close by you uses PM service and if it works...
12-16-2021 12:23 PM
try to do troubleshoot your device,
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, let them check it out your line and Explain your issue to them can solve, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by Submit a Ticket,
Good Luck...
12-16-2021 11:32 AM
OK, will give that a try, thank you.
12-16-2021 11:32 AM
@crosbyoverovi wrote:I restarted it a few days ago.
Plan is active.
If possible, try the sim in an unlocked phone. If the problem clears up...you'll know the phone is the problem, not the sim.
12-16-2021 11:29 AM
Plan is active.
12-16-2021 11:26 AM - edited 12-16-2021 11:29 AM
@crosbyoverovi wrote:Call drops right away when I try calling out and when calling my phone it goes right to voicemail. I think I have had this problem right after my phone was reset. Is this a problem with the SIM card?
Try restarting your phone.
Try the sim in a different phone, if one is available.
Log in to your account...is plan Active ?
