Can't Text in US
Crashnot
I have Add-ons for US talk, text & data. Talk works but texts do not come in or go out and I have no data. There is good cell coverage in this area for US phones. Any tricks I need to do on my settings?
10 REPLIES 10
Crashnot
Cellular Data Options "Roaming On"
Data Roaming "ON"
Voice & Data "LTE"
@Crashnot wrote:
I just bought US data an hour ago, so would like to think I can get something from it.
HI @Crashnot try reboot the phone
and you had bundle before and buying data this time? if you re-buy the SAME roaming addon before the 15 days expiry, it wont' work, and you will need agent's help to sort it out
If data does not work still submit ticket with agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Crashnot
It's always on with my phone.
Crashnot
HI @Crashnot   then this is normal, iMessage uses mobile data.
you have no choice but to either buy more data or just stay with sms
But if you need to buy more data, likely your 15 days not expired yet, you need PM agent's help.  Please submit a ticket with agent to ask them to help re-buy early
Or your other choice is to just buy a different one.  If you got bundle earlier, then buy the roaming data only this time
You need to turn data "ROAMING" on, not just data.
Crashnot
both iMessages and SMS options work now. But still no internet capabilities. Four bars for cellular access.
Crashnot
Data is always on as home is rural so we need it. But I had to go turn on SMS even though iMessages started sending. Still don't have data so trying to restart phone for lack of any other options.
DennyCrane
On your device make sure you enable data roaming in your network settings; it's usually off by default. Then ensure you're imessages are set to send via SMS when there's no data.
HI @Crashnot  are you using SMS or iMessage/RCS?
remmeber iMessage or RCS are not true text, they need data.
If you are sending sms but not working, please check if you phone connected to T-Mobile still
(but, I have a feeling you were  using iMessage or RCS)
