Text attachments
01-07-2025 01:51 PM
I have an iPhone 14 Pro and can’t send text with attachments to non iPhones. I can send a regular text but cannot send a text with an attachment.
Service
01-07-2025 04:34 PM - edited 01-07-2025 04:34 PM
Just do a hard restart. Push volume up then volume down and hold the power button and wait for the Apple logo then let go the power button.
01-07-2025 02:08 PM
@RobDM wrote:Yes. I can send attachments with iMessage but not with MMS. Error message says to enable MMS but I already have it enabled.
@RobDM , install the latest iOS 18.2.1 and enable RCS protocol for texting. With that you should be able to send attachments to anyone else who is also running the RCS protocol regardless whether they are android or iOS users.
01-07-2025 02:02 PM
01-07-2025 01:54 PM
hi @RobDM
make sure you have the latest iOS and Carrier profile
try reboot the phone
and go to settings and enable both iMessage and Text Message (Settings-> Apps-> Message)
try Reset network settings on your phone
01-07-2025 01:52 PM
you have enabled iMessage? and you are sending to iPhone users or Androids?
