Can send texts and phone calls but can't receive them
jessgies
Hi there,
I just switched to Public Mobile from Rogers about 2 weeks ago. I just found out that I am not receiving text messages or phone calls since. I can make phone calls and my texts go through, I just can't receive anything
How can I fix this? Is my number ported incorrectly?
Thank you in advance!
2 REPLIES 2
Dunkman
@jessgies
You are correct.  Your port is likely stuck.  If you have your Rogers SIM card, it should still be working.
Here is additional information:
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
As stated above, you will need to contact moderator to fix the port.
JK8
@jessgies
Contact a moderator (Public Mobile representative) for assistance:
(second option below is easiest to submit a ticket)
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
