06-04-2022 11:56 AM
Hello, I have just signed up with Public Mobile, I have an Asus Android phone and I can not use my data, my account is showing active and that I have data available but I can’t use it on my Asus phone, please help.
Service
06-04-2022 12:35 PM
All fixed thanks for all your help
06-04-2022 12:32 PM
Thank you for your quick response, it worked I now have access to my data 🙂
06-04-2022 12:23 PM - edited 06-04-2022 12:23 PM
Hi @Roxanne1923 having ipv4 there should be fin
Try these:
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN roaming protocol
IPv4
MVNO type
GID
MVNO value
4D4F
06-04-2022 12:16 PM
Hello, it has the APN protocol as IPv4 and APN roaming as IPv4 is that ok or should I take it out
06-04-2022 12:10 PM
@Roxanne1923 Data issue like this would be caused by incorrect APN settings. You can manually change it Or Reset Network setting is the easier way to do
But some phones might need to do a complete Factory Reset with the PM Sim inside
06-04-2022 12:04 PM
If everything else works (calls/SMS in/out) it has to be APN settings.
For android
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
06-04-2022 11:58 AM
@Roxanne1923 Voice working? likely it is an APN issue.
first try to Reset Network and see if it works
If still fails, check the APN settings , compare it with
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
06-04-2022 11:58 AM - edited 06-04-2022 12:08 PM
It sounds like your phone settings
first thing do a network reset if that doesn’t fix it check apn settings
Step by Step APN configuration
Step1:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Blackberry
OS 10 - Settings > Network and Connections > Mobile Network > Tap the settings icon (dented wheel)
Windows
Windows 8 Step 1 Settings > cellular > Add or Edit internet APN
iPhone
Step 2:
You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
Step 3:
Select Save/Done. Select Public Mobile to connect to the Public Mobile network
