Can not sent picture
Lisong
Hello,
My phone suddenly can not sent out picture,  but all other service  is ok. I can sent text message
How Can I do in this case
Lisong
Thanks,
I have made new settings as per your list above, it works now.
Regards,
Linda
@david771234 @Lisong
Here is the background information about thebtexy issue that o7nmight be affected by:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or        default,mms,agps,supl,fota,hipri
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
Phil_Adelphus
@Lisong  Perhaps it is affected by the MMS APN changes, is your phone on the compatible list here:
https://www.publicmobile.ca/en/on/get-help/articles/picture-messaging-updates
