3 weeks ago
I can't change my APN on my android phone. My messenger won't be able to send picture.
3 weeks ago
@Swq1149 what do you mean you can't change it? You mean uou don't know what it should be?
See if your phone has the following. If not, delete and add the below
APN: sp.mb.com (could be all caps)
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
