06-05-2022 02:44 PM
I can not log into my account.
It always says "your login failed. Please try again" no matter what i do. Even when i try to reset my password.
I haven't used the account for 8 months but want to start using it again.
Any advice?
Thanks,
Scott
06-05-2022 08:49 PM
You will need a new SIM and get a new phone number since you haven’t kept up with payment in 8 months.
06-05-2022 02:54 PM - edited 06-05-2022 02:56 PM
@pizzascotty If you have been having this problem for months, then I think you need to submit a ticket to customer support and ask them to take a look at your account. Here's a link to chatbot: https://www.publicmobile.ca/get-help/articles/contact-an-agent
edit: oops, I see you haven't used the account for 8 months, so yes as mentioned your account is closed. Sorry.
Usually clearing cache/cookies and using privacy/incognito mode will allow you to login without difficulties, but see what CSA's can suggest.
06-05-2022 02:53 PM
@pizzascotty hi after 90 days suspended your account is closed permanently
06-05-2022 02:53 PM
After 90 days without payment...your PM account is closed down for good. You'll need a new sim to start a new account.
