06-07-2023 07:30 PM - last edited on 06-07-2023 08:50 PM by computergeek541
I registered a sim card and got a new number . This number belongs to someone else. I can receive a 6 digits code to log in to my account to change the number. Need your help. Please advise.
06-07-2023 08:04 PM
@Vlad5 So you registered a new line, you picked a new number and found out the number belongs to someone else and you cannot login ?
Assigning an old number to new account is a common glitch. But no worry, just follow the steps
06-07-2023 07:44 PM - edited 06-07-2023 07:45 PM
I didn't notice earlier that your post heading is that you cannot login into your account. You need to use a clean browser so clear cookies and cache or try incognito mode to login. @Vlad5
06-07-2023 07:37 PM
@Vlad5 I'm not sure that a number can be provisioned to two different users. How do you know it belongs to someone else?
If you want to get a new number that's very straightforward. Log into my account, go to profile and you can edit the phone number and grab a new number.
06-07-2023 07:37 PM
@Vlad5 - do you mean you CANNOT receive the code? Select 'resend code' once twice or however many more times until you get the email option.
This is a public forum, please edit your post to remove any personal information. To edit it, hit the down arrow at top, right of your post.
The number assigned is not supposed to belong to someone else, but guess what, this sometimes happens ! 😕
Go into My Account and change the phone number (free to do so up to 4 times in 30 days), then your issue should be gone.
06-07-2023 07:36 PM
Please don't post your number here as it's not safe and anyone can see it. You can do an edit and remove it by clicking on the little arrow in your post.
I'm sure you can change your phone number in your phone account. Try using the profile page and there must be an option to change it and public doesn't charge for changing numbers unless that's also one of the changes around here. @Vlad5
