Can not call anyone
soykanyal
Hello eveyone, first i would like to start with , i deposit money in my account today (60$) , also it shows 0$ amount due , despite everything still i can not call anyone or text , additonaly it says next renewial is 29 agu. How can i buy a plan right now to use  please can some one help me
37 REPLIES 37
@Tamimalnaser wrote:
I got it from UAE,
@Tamimalnaser  Since your make model is not listed you need to click  here
include the make and model and ask them if it is compatible with Public Mobile 3G.
Tamimalnaser
I got it from UAE,
Changed the phone, the Sim is working so it's the phone model,
Can I do something about it or change anything?
@Tamimalnaser  Where did you purchase the phone from? Might not be compatible if the sim is working in another phone without any issues must be missing the 3G bands
@Tamimalnaser
Network reset first.
If that does not work, factory reset of phone (make sure to back up information)
Tamimalnaser
@Tamimalnaser
Your phone should be compatible with Public mobile.
https://www.gsmarena.com/huawei_y9_(2019)-9324.php
Did you port a number from another company or activate a new number?  Does your data work?
You could try your PM SIM card in another phone to determine whether it is a hardware issue versus PM service problem.
It's Huawei Y9 2019
@Tamimalnaser
 Public Mobile has partnered with willmyphonework.net as the new compatibility checker.If you can’t find your make and/ or model, provide feedback directly here.
Did you check your phone for compatability?
Tamimalnaser
It's Huawei Y9 2019
Tamimalnaser
Huawei Y9 2019
@Tamimalnaser  What's the make and model of your phone?
I don't get any message when I try, It just keep trying to call till it hang-up automatically without getting any message
Could it be something with your settings in your phone?? I don't know...
I suggest you to write a message to the moderator for more help here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and explain with details what happened. Waiting time is few hours to 2 days...good luck.
Tamimalnaser
I tried to call without 1 and didn't work,
And no I don't have any message of that kind
What does it say or do when you try to call?
Tamimalnaser
It's totally new plan,
It's showing active
I can text but I can't call
Strange...did you try different number? With or without the 1 in the beginning...just to try???? Do you have a message that say that you don't have any plan for call or long-distance???
Tamimalnaser
It's showing active
Tamimalnaser
  • This plan includes: -
  • - 500MB + 500MB at 3G Speed
  • - Unlimited Canada-wide Talk
  • - Unlimited International Text
It's 25$ per 30 days
Ok what is shown in your self-serve account on the first page ACCOUNT ACTIVE or SUSPENDED? And can you text? Is it after a changing plan after a renewal? ....
Tamimalnaser
I have the same problem
You need to give us more details of your problem...Which plan...?
Tamimalnaser
Shazia_K
Retraité / Retired
Retraité / Retired
hehe don't be sorry! I know you do @Luddite Heart
@Shazia_K Sorry, sould have had more faith in your isues tracking system. Smiley Sad
Shazia_K
Retraité / Retired
Retraité / Retired
Hey @Luddite
yes, @paryse's phone is not unlocked, I recommended to get it checked and unlocked if possible.
Maybe @paryse can update us later?
Thank you guys 😄
Shazia
@Shazia_K Is paryse 's issue being addressed?
paryse
I gave her my sim card number and email address. waiting for her reply
paryse
I did. Thank you 🙂
srlawren
@paryse have you responded to @Shazia_K via private message?  Please give us an update when you have a moment, so we know if your issue has been resolved.
soykanyal
Sorry for late respond , my problem is solved by shazia. I would recommend you to contact with them .
Shazia_K
Retraité / Retired
Retraité / Retired
@paryse
I'm sorry about this,
Can you please reply back to my private message?
Thanks,
Shazia
