US Roaming-Unlimited talk/Txt
chandara
i bought the add on $15 for US Roaming - unlimited talk/txt -- i am traveling to US MN --- text seem to be working fine but unable to make out call or receive call.
Please help
thank you
2 REPLIES 2
Phil_Adelphus
@chandara  Possibly your phone needs a 3G network, which the USA has shut down so if your phone is not VoLTE capable and enabled then voice calls will only work on T-Mobile's 2G.  Maybe try connecting to T-Mobile and see if it will work.  Edited to add, and yes as @Chalupa_Batman  said, make sure data roaming is turned on.
Chalupa_Batman
Hey @chandara
You have to first make sure your phone is VoLTE enabled. Then go into your network settings and turn off automatic and pick T-Mobile. Then make sure Data Roaming is turned on. Then reboot. Should be up and running in Minni.
