11-04-2023 04:53 PM
11-04-2023 07:28 PM
@hairbag1 wrote:
@Hollister wrote:Use this tool to confirm your number is portable to PM.
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
It says port to Koodoo, but assumed to also work for PM ?
Yes, I am assuming if you can port to Koodo, then also PM since they are all in the same family.
11-04-2023 06:44 PM
If you got your number from Telus or Koodo…no problem.
Most numbers are portable from a Canadian carriers. Very slim if you can’t.
11-04-2023 05:11 PM
11-04-2023 05:07 PM
11-04-2023 05:02 PM - edited 11-04-2023 05:03 PM
are you wanting to port IN or OUT ?
added...read here..
https://www.publicmobile.ca/en/bc/get-help/articles/transfer-your-number
11-04-2023 05:01 PM
Yes you can. Just need to make sure it’s an active mobile or landline number. It also needs to be from a service provider in same local calling area.
