09-14-2023
02:24 PM
09-14-2023
03:33 PM
computergeek541
I recently got a new phone and just wondering how can I transfer my esim to this?
09-14-2023 02:36 PM
Thanks Guys! why does PM just put this on there FAQ's.
09-14-2023 02:33 PM
09-14-2023 02:32 PM - edited 09-14-2023 02:33 PM
Yes of course, as long as you are logged into the account associated with your number the purchase will connect your number to the E-SIM
09-14-2023 02:30 PM - edited 09-14-2023 02:32 PM
@GGCDVG Yes that the whole point of logging into the app first to keep you same number and plan
09-14-2023 02:29 PM
can I use the same number?
09-14-2023 02:26 PM
HI @GGCDVG
yes, you can transfer your number to the new phone but you need to buy a new esim
On your new phone, download PM app, login and go to Subscription & Add-on page and buy new eSIM and install using the app
09-14-2023 02:26 PM - edited 09-14-2023 02:26 PM
@GGCDVG .no but you can rebuy eSIM in the app log in with new phone and go to subscription add on page and notice at the bottom shop sim . Select it and you can then choose eSIM download and install it
09-14-2023 02:25 PM - edited 09-14-2023 02:34 PM
You will need to purchase a new E-SIM for $5 and then add it to your phone using the app or QR-Code.
This can be purchased in subscription and add-on’s and then the shop sim option will be near the bottom.
